xenon lowbeam headlight failure
Old Nov 9, 2008 | 02:50 AM
ben0747's Avatar
Default xenon lowbeam headlight failure
My LH side head light (low beam) is not working, due to a large rock smashing the glass, I have checked the bulb and the ignitors, both are fine, I also checked all fuses and they are ok, message comes up on screen dipped low beam failure, then, head light failure, then multiple bulb failure, but RH headlight is working fine, Im not sure if the head light leveling is effected, last night it had a little spark coming from the bulb, but now no spark, what things should I check or what could be causing it?
Many Thanks Ben
Old Nov 9, 2008 | 07:25 AM
Default RE: xenon lowbeam headlight failure
The ballast might have gone bad.
Old Nov 9, 2008 | 04:40 PM
ben0747's Avatar
Thats what I was thinking how do I get to the ballast ? and what do I need to do to fix it?
Old Nov 9, 2008 | 08:45 PM
The ballast should be under the headlight.
You need a new ballast.
lancelot
Sep 10, 2019 09:20 PM
jaippolito
Nov 26, 2013 07:58 AM
bna1dew
Nov 8, 2013 02:24 AM
frusyks
Aug 7, 2011 08:26 AM
Jose Cruz
Feb 16, 2009 06:28 PM
