Yaw Sensor Signal Missing - 2007 S60 2.5t
Old Aug 14, 2022 | 07:02 PM
mrflores's Avatar
Post Yaw Sensor Signal Missing - 2007 S60 2.5t
Hey all
Have had this anti skid warning for the longest time and have searched all over for a fix on various forums. Currently receive codes BCM-0114 (Communication with AYC-sensor signal missing) and BCM-0138 (Voltage supply, AYC sensor faulty voltage). I've cleaned the connectors on the sensor and BCM even though their were no signs of corrosion or water intrusion in the passenger foot well. I've probed the CAN lines and get about 1.8V on the CAN low side, and 3.3V on the high side. The problem may be voltage delivery to the sensor itself i'm guessing? If so, where should I start?
Thanks
Old Aug 14, 2022 | 09:00 PM
Thanks
With a scan using a compatible scanner that can give you places to look and possible solutions. If you were using VIDA - each code would have a list of possible problem areas and a list of things to check to hopefully isolate the problem. A common problem with codes similar to yours - is bad connections INSIDE the abs module. Solved with a replacement module from a vendor such as xemodex or many DIYers have done full to half *** self repairs.
Old Aug 15, 2022 | 06:13 PM
mrflores's Avatar
Thanks for the reply!
Yes I have been using VIDA to scan my codes. The conflicting thing though, is that inside the information portion of the error code BCM-0114, it specifically states that this code doesn't have to do with an internal fault in the bcm and shouldn't be remedied by replacing the module. Possible sources are contact resistance in terminals, which I cleaned and didn't do anything. Open circuit in the wiring between the bcm and sensor. Yaw sensor not connected, or an internal fault in the yaw sensor. The sensor is definitely connected but not getting voltage, so Id like to ideally trace the wiring and rule that out next. I was just curious to see if anyone had experience with these two specific codes appearing at once and how they remedied it. Another possible concern may be my battery as its 8 years old atm and puts out 11.8V in position 2. Id assume that should be between 12.2-12.4V.
Old Aug 15, 2022 | 07:46 PM
You might want to replace your 8 year battery
Old Aug 15, 2022 | 08:04 PM
mrflores's Avatar
Thats definitely on the list lol. Im just amazed that it keeps going.
2008s60
Feb 23, 2022 09:57 PM
axelm
Jul 3, 2015 08:48 PM
curtorous
Jan 2, 2011 10:30 AM
RomoGuy
Jun 24, 2008 05:53 PM
