1998 Non-turbo S70 with cylinder 2 misfire
Old Jan 6, 2010 | 03:47 PM
ged1995's Avatar
Default 1998 Non-turbo S70 with cylinder 2 misfire
I've got this progressively worse problem over the last few days. The car will have difficulty accelerating while still under 2200 RPMs. I don't have the misfire while revving the engine in park or reverse. Any thoughts?
Old Jan 7, 2010 | 04:21 PM
Paulie's Avatar
Have you taken a look at your plugs? How old are the wires, cap, and rotor?
Old Jan 20, 2010 | 08:41 PM
gltgreco's Avatar
its more common for the engine to misfire under load, thats why it is not misfiring when you just rev it, try accelerating up a hill or things like that and it likely will, its probably yous plugs or rotor or dist. cap, you should just replace them all its cheap and easy, ipd makes a good replacement set of wires.
Ablorx
Jul 4, 2014 08:33 PM
rspi
Mar 25, 2014 02:22 PM
phiber
Jan 6, 2013 10:49 PM
schmuecker
1998-2000 model year V70
12
Jul 27, 2012 01:26 AM
