1999 S70 Gasket and Seal Replacement
Old Sep 2, 2008 | 06:45 PM
MonsignorRonan's Avatar
Default 1999 S70 Gasket and Seal Replacement
Greetings and help if you can.
My volvo was going through a litre of oil every 500 miles. My mechanic realized that the oil was burning through a bad seal.
We replaced all seals and gaskets to the tune of a lot of money.
Four thousand kms later, when I go to work or return (100 miles each day in driving), I am smelling a burning rubber smell.
I can see smoke coming from under the hood. When I raise the hood, I can see that the smoke is coming from the back of the engine. This is not rubber at all. I am sure it must be oil. Should I be alarmed? or Would it be normal to experience a little oil buring off after such a procedure?
Most of the summer the car drove only about 20 minutes to half hour a day. Now after some more series driving (two hours a day), I am seeing smoke burn out from behind the engine.
I am guessing that I should be contacting the mechanic and having him inspect his work. They only work on Volvos at the shop I go to. Is there something he may have done wrong?
Thanks
JD
Old Sep 2, 2008 | 06:46 PM
Default RE: 1999 S70 Gasket and Seal Replacement
Sorry,
I meant to say we replaced all seals and rings on the engine.
Old Sep 2, 2008 | 07:25 PM
Turbo or not?
Old Sep 2, 2008 | 08:02 PM
I don't think turbo related but I will sure check.
I was thinking that since the rings and gaskets were just changed, that perhaps something went wrong with the procedure?
Any other thoughts?
Thanks
Old Sep 2, 2008 | 08:16 PM
The o-ring on the turbo pipe where it enters the block might be bad. Thats what I was thinking.
Old Sep 2, 2008 | 09:21 PM
Thanks for the tip Moderator!
I will check into that as well.
JD
sktrmoss
Aug 25, 2012 07:18 PM
Jetstreamer
Jun 14, 2012 09:32 PM
speedracer67
Jul 16, 2010 10:12 AM
moosepucky
Aug 6, 2008 04:37 PM
sameyeham
Feb 18, 2008 05:29 PM
