1999 S70 hot start issues
Old Jul 3, 2011 | 05:06 PM
nyckid's Avatar
Default 1999 S70 hot start issues
This one is really getting to me. 1999 S70 GLT/Auto. 163k miles. Just picked it up 6 weeks ago. Changed plugs, coolant, thermostat, tranny fluid, oil, oil filter. Replaced the ABS module from Mid-West ABS (thanks, Matt). This car starts fine 1st thing in the morning. If I drive it for 30-45 minutes, run into the store or stop for fuel, she gives me a very hard time starting again. 10-30 turns of the key. The car turns over strong (new battery), just doesn't catch. I just have to sit and wait for it to cool off. To top things off, if I let the car sit in the summer Sun before I start it, it does the same thing just as if I drove the car, but the motor is completely cold. I am baffled. Thank to all in advance, Jason.
Old Jul 3, 2011 | 07:08 PM
VTBricked's Avatar
Leave it in the sun on a hot day and troubleshoot: fuel, spark/signal. Is it throwing any CEL codes?
Old Jul 3, 2011 | 07:20 PM
My guess would be a MAF. Unplug it and see if it starts.
Old Jul 4, 2011 | 07:31 AM
nyckid's Avatar
No CEL. I had fuel pressure tested cold and after she was warmed up, same results. If it starts with the MAF unplugged, then it's the MAF?
Old Jul 4, 2011 | 08:08 AM
Just a guess. I don't think your car has an idle control valve since it has the electronic ignition.
Old Jul 4, 2011 | 09:47 AM
nyckid's Avatar
Pulled the MAF and it didn't start. Pulled relay for fuel pump., going to remove it and see for damage. Any ideas for/against jumping the relay?
Old Jul 11, 2011 | 09:39 AM
nyckid's Avatar
OK, for all those that have similar issues. I pulled the relay and tried jumping with a paper clip. Car started, so i decided to clean the contacts on the relay and where they go in on the fuse block. Car starts EVERY time. Looks like a cheap fix. Been good for 1 week now. Keeping my fingers crossed. Thanks for all the responses.
Jason
Old Jul 11, 2011 | 10:11 PM
gdog's Avatar
Not to rain on your parade but I suspect you may have just disturbed the fuel pump relay causing it to now work more reliably, for a time..
Ck out these threads for more info:
Fuel Pump Relay - Intermittant: FIX - Volvospeed Forums
http://www.matthewsvolvosite.com/for...pic.php?t=9681
Old Jul 13, 2011 | 05:02 PM
Crush's Avatar
replace the relay.
crush
MineMine1
Nov 9, 2012 02:05 PM
rezology
Jun 13, 2010 10:42 PM
blasta510
Oct 18, 2009 07:51 AM
beardo265
Sep 27, 2007 09:24 AM
