1999 s70 p0108
Old Aug 21, 2010 | 01:50 PM
Elsid's Avatar
Default 1999 s70 p0108
I have a 1999 S70 and it is getting a P0108. I can clear the code and on restart of car the light comes back on within 1 second. The MAP sensor looks fine and the connections are secure. I've done some research on and am hoping replacing the part will correct (especially how it comes back so quick once turned off..) Any help would be great from ones that have experienced this code and now don't have... Also on the car, the ***** on dash are sticky when its hot in the car... Can these be replaced (just the *****), cheap ?
Last edited by Elsid; Aug 21, 2010 at 02:26 PM. Reason: added another question, same car
Old Aug 29, 2010 | 12:16 PM
EEaudio08's Avatar
The ***** in my car were sticky too, since I bought the car in '04. I used baking soda and water to clean them off, and they feel like brand new. I would try this out first, before buying new ones.
Old Sep 2, 2010 | 08:53 AM
Elsid's Avatar
The P0108 is the item I need help with (mainly). Anyone successfully corrected it (by replacing the MAP sensor or some other way) ?
Old Sep 2, 2010 | 10:20 PM
EEaudio08's Avatar
Originally Posted by Hosanna
In 2000, the SE trim level was made available to the S70 "base" and GLT model. Therefore four trim levels were offered, Base, Base SE, GLT, and GLT SE. Trim levels were named differently in Europe Starting for the 2001 model year, the S70 was replaced by the S60, as the S80 had been introduced in 1998.
An S70-R version which was not released in North America was introduced later to offer higher performance. The engine was an extra-tuned edition of the 2319 cc unit, rated 250 horsepower 186 kW; 253 PS and 350 newton metres 258 ft·lbf for models fitted with a five-speed manual gearbox and limited slip differential. Models fitted with a four-speed automatic gearbox rated 240 horsepower 179 kW; 243 PS and 330 newton metres 243 ft·lbf.
Why are you posting this irrelevant information every time you post?
Old Sep 7, 2010 | 10:32 AM
Elsid's Avatar
I have replaced the part but still exact same symptoms. Car runs fine otherwise. Wondering if the S70-R ever gets the P0108 code..
Old Sep 9, 2010 | 12:16 AM
gdog's Avatar
stupid question dept; is there a vacuum line going to the MAP sensor? Is it hooked up to the intake manifold?
Old Sep 9, 2010 | 08:30 AM
Elsid's Avatar
Yes, it mounts under the plastic 'overhang' back / top of radiator in the middle..
Old Sep 9, 2010 | 08:32 AM
Elsid's Avatar
And vacuum line from it goes to intake
cjbmustang
Feb 11, 2013 08:11 PM
volvorecycle
Aug 1, 2009 03:10 PM
lordhowe
Sep 26, 2007 03:34 PM
TBoone
Aug 8, 2006 12:52 AM
hordezla
Apr 27, 2006 09:40 PM
