200 S70 Ignition issue
Old Jul 15, 2010 | 09:46 PM
Delirious's Avatar
Question 200 S70 Ignition issue
Having trouble turning the ignition key to start the car.
Seams random and only when trying to start the car the key will not turn at all past the insert position (0), if you remove the key and insert it again it may turn the second or third insert time. Originally the shifter *** was causing problems removing the key as well, but I sprayed some silicone in there and that seams to have cured that issue.
Has anyone experienced this issue?
cheers
Old Jul 15, 2010 | 11:49 PM
HeadDragon's Avatar
The cable is not returning has been my experience so it does not know you are in Park. Lube the key slot though and see if it clears up. Silicone is better than graphite as it can get into more places but will leave the key oily.
Old Jul 21, 2010 | 05:54 PM
Delirious's Avatar
Unhappy No GO!
Tried the silicone through the key hole trick with no success. Any other suggestions it's a pain in the ... inserting the key in and out till it works.
Thanks
Old Jul 21, 2010 | 08:10 PM
viperbite's Avatar
give some pb blaster a shot. a little stronger of a lubricant. but it carries a bit of a smell lol.
Old Sep 4, 2010 | 09:03 PM
Delirious's Avatar
Talking Grease her up!
Thanks for the help, you were right about the lubricant. Frustrated after the 1st attempt and scared of the prospect of having to replace the key cylinder, I sprayed so much silicone and penetrant in the key hole that it was leaking out of the steering column cover! To my astonishment and total relief after a few treatments like that, it is working almost every time you turn the key now.
Old Sep 5, 2010 | 11:15 AM
HeadDragon's Avatar
Because I downshift a lot to save using my brakes my shifter works normal now. It used to have to be pulled out in park and in drive and reverse.
rb26dett
Sep 22, 2010 11:19 AM
troche
Dec 9, 2007 11:31 AM
MIK911
Jul 22, 2007 01:07 AM
giacomozzi
Jun 13, 2006 02:09 PM
plynhrd117
Dec 12, 2005 01:13 AM
