2000 S70 GLT - Starts then stalls
Old Jun 29, 2012 | 11:46 AM
T_Genn's Avatar
Default 2000 S70 GLT - Starts then stalls
My 2000 S70 (205k miles) will turn over, but once I release the key it stalls. This has happened on occasion before, but I always managed to get it started after a couple of attempts. I have not noticed any correlation with the weather. When it does start, no warning lights come on. I haven't coded it yet, currently just sitting at work thinking about it. Any ideas?
Old Jun 29, 2012 | 11:47 PM
gdog's Avatar
Without more diagnostic info any suggestion as to what it could be would be strictly a guess.
That being said, I would ck the fuel pump relay first; a common issue on these cars.
Old Jun 30, 2012 | 02:31 AM
Henry Jones Junior's Avatar
It stalls when you release the key right after starting it? Can you get it in gear or anything?
Have you tried starting it in neutral?
Old Jun 30, 2012 | 05:11 AM
+1 With GDog. Cranking but not starting is likely fuel pressure related. If you find that you have good fuel pressure, check for spark.
Dan Daws
Jul 19, 2015 12:05 AM
rspi
Mar 1, 2014 06:38 PM
pkir199a
Aug 19, 2013 07:33 PM
mowntnbkr
Oct 19, 2011 07:15 AM
240tank
Jul 1, 2008 04:35 PM
