2002 volvo V70..dash lights,fuel light etc not working
Old Sep 13, 2014 | 08:13 PM
intermornings's Avatar
Default 2002 volvo V70..dash lights,fuel light etc not working
on my Volvo 2002 v70 suddenly dash lights went of..so now I don't have no dash light, engine RPM and speed gage doesn't work..it did work next day after I discovered that fault but not for long..i have checked fuses near engine ..seems like OK..is there is anything else to check..obviously yes,does anybody had this problem and know what to check?thanks guys
Old Sep 13, 2014 | 08:32 PM
oragex's Avatar
Well, it got the dying DIM (dash) symptoms unfortunately. Typically, it's a few electronic parts inside that go wrong. Owners usually sent the whole dash (the part with the gauges) to a specialized repair shop (have a look un Ebay) for around $250. Remember not to use the ignition key (even better, disconnect the "-" battery cable) while the DIM is disconnected, otherwise you will get a airbag warning message that can only be cleared at the Volvo dealer for around $100.
One alternative, is to find a micro-electronics repair shop in your area. They shouldn't be charging too much and can definitely carry the repair.
The attached photo shows the components with the issue, inside the DIM (it's easy to remove the cover to reach these components, just a couple of phillips screws). On my car, the problem was the parts inside the red circles (replace them). Other say it's the chip marked with green - just re-flow the soldering and it will work fine (takes 5 minutes to do it with a re-flowing machine).
One last option is to buy a used DIM off Ebay (around $100) that matches the miles on your car (it will display the miles from the donor car), and that has all the model numbers on the side matching the ones from the DIM in your car (there are about 5 numbers, all must match).
Attached Thumbnails 2002 volvo V70..dash lights,fuel light etc not working-volvo-dash-chip.jpg
Old Sep 14, 2014 | 06:32 AM
Thanks Oragex..great help. Now I know what is happening..Today I had a sunday trip ,at the beginning it did not work but after the hills it suddenly started to work...and it still does..well,see what happens tomorrow..many thanks
Old Sep 14, 2014 | 07:10 AM
oragex's Avatar
Indeed, at the beginning is on and off, it usually depends on the temperature inside the cabin.
Old May 15, 2018 | 04:07 AM
Snyper Cyrus's Avatar
Very old thread, but biting my fingers, someone could help me out.
I have a V70, 2001. Been a great car. The lights in the dash don't work, except only ONE, the Engine Check light. And the power windows do not respond as well.
Any help? Otherwise the car starts just fine. But dangerous to drive without the DIM warnings, and all.
Regards
eric1164
Oct 28, 2025 12:19 PM
rspi
Mar 22, 2014 09:32 PM
zloetakoe
May 28, 2011 07:29 PM
104octane
Jun 11, 2009 03:04 PM
104octane
Engine & Internal
Jun 11, 2009 03:01 PM
