2004 V70 Flood damage, runs but various electrical issues
Old Mar 8, 2019 | 06:17 PM
PaulP's Avatar
Default 2004 V70 Flood damage, runs but various electrical issues
Was forced to drive my 2004 V70 through some standing water. Ended up with about 4" of water on the cabin floor. Was able to get it started and it seems to be running fine.
There are, however, several electrical issues. I've been dewatering as best I can, and some things are improving. Gas gauge not working, fuel door won't open, rear door locks
not working, check engine message is showing. Wondering if there is a particular place that I should concentrate on, or if there are several areas that could be causing problems.
Any help would be appreciated. Thank you.
Old Mar 9, 2019 | 09:57 AM
There are various relay panels and CEMS (central electronic modules which have smaller relays) in the car. Search online for a wiring diagram then check the owners manual for the location of the secondary relay boxes to see which are in play for your problems. For the rear doors you may need to pop off the door cards to see if the water didn't drain and if there's residual moisture.
kensager
Mar 27, 2023 02:40 PM
aznav
Jul 14, 2018 12:45 PM
JBren
Oct 19, 2017 08:28 AM
Bwc1
Sep 20, 2014 01:25 PM
jmc00v70
Mar 8, 2007 08:30 PM
