2nd timing belt interval ???
Old May 8, 2008 | 01:10 AM
saved_one's Avatar
Default 2nd timing belt interval ???
Hello to all, i am a new owner of a 1998 s70, the person i bought the car from had the timing belt changed at 75k. I now have close to 130k on the car, when should the timing belt be replaced for the second time??? Also, i have this light that stays on inside my dash that says "service", i thought it would go out after i changed the oil but it didn't, what is up with that??? Any responses are appreciated in advance....
Old May 8, 2008 | 05:15 AM
Thecapeman's Avatar
Default RE: 2nd timing belt interval ???
Hi Saved_one, welcome to the Forum.
A new timing belt at any age can never hurt, only help. A lot cheaper to replace the belt than the alternative outcome. Regarding the Service Light see the following linked post. I'm not sure these instructions will work on a 98, but give it a try. https://volvoforums.com/m_2801/tm.htm
Rick
Old May 8, 2008 | 08:05 AM
saved_one's Avatar
Thank you for the welcome and the tip on resetting the light, i'll try it today and let you know how it goes...
Old May 8, 2008 | 10:40 AM
samadkins29's Avatar
The belts need to be done every 75,000 miles I think.
Old May 8, 2008 | 11:50 AM
JimKW's Avatar
You can not reset the Service Light on the 97 and 98 model years, only done by the dealer. The timing belt interval is every 70K or 5 years whichever comes first. If I were you I would have it changed and then you know you are good for another 5 years or 70K.
Old May 8, 2008 | 12:51 PM
Ahmed's Avatar
Not only do you need to replace the belt but you also should replace the tensionors and idler pully also. Because if they go bad it will damage the engine.
Old May 8, 2008 | 06:47 PM
saved_one's Avatar
That is kind of what i thought, i just wanted to ask some of you guys who are veteran Volvo owners, thank you for the response...
mt6127
Oct 28, 2025 09:33 AM
2012
Feb 9, 2014 08:26 AM
ScottyJ
Nov 9, 2012 08:18 PM
GadgetRick
Dec 3, 2011 08:47 PM
537playing
Jun 8, 2011 05:47 PM
