98 S70 dies after starting
Old Oct 13, 2011 | 02:38 AM
stevencbrown's Avatar
Default 98 S70 dies after starting
Hello,
I have a 98 S70 non-turbo that always starts fine but, sometimes (but not all the time) die after a few seconds. Seems like a fuel starvation issue or ignition cutoff. No fault codes from OBD II.
After a couple of restarts it will run perfectly until the next day. So, the issue comes and goes.
I have replaced the neutral safety switch, checked all the vacuum lines, mass flow sensor, etc. Nothing seems out of place or broken.
Now I'm thinking of replacing the fuel pump relay.
Any ideas would be greatly appreciated.
Thanks,
Steve
Old Oct 13, 2011 | 08:38 AM
Does it only do it when the car is cold? Does it run rough with the car is cold just after start?
Old Oct 13, 2011 | 09:42 PM
gdog's Avatar
Originally Posted by stevencbrown
Hello,
Thanks,
Steve
Classic symptoms...
Old Oct 15, 2011 | 12:23 AM
Yes, it dies when it is cool. When it runs it runs perfectly, never runs rough
Old Oct 15, 2011 | 10:31 AM
Could be the coolant temp sensor.
David Breitenfeld
May 9, 2015 07:32 AM
UTofSH
Feb 16, 2015 10:27 PM
ldou0110
Nov 3, 2014 05:49 PM
fravid90
Aug 10, 2014 11:27 PM
free1959
Sep 11, 2011 02:59 PM
