99 s70 check engine light will not go off ?
Old Feb 27, 2010 | 02:36 PM
klod622's Avatar
Default 99 s70 check engine light will not go off ?
I have a 99 s70, the check engine light came on, had it scanned and came up with code po135 o2 sensor bank 1 sensor 1. i replaced the part and the light is still on. i cleared all codes and the light comes right back on with the same code.
i called the dealership and he said something about needing a software update if you do anything with the electric system. never heard of that before.
any help would be greatly appreciated
Old Feb 27, 2010 | 03:36 PM
Did you use a Bosch sensor?
Old Feb 27, 2010 | 10:17 PM
klod622's Avatar
no, it was a denso 234-9020
Old Feb 28, 2010 | 07:45 AM
Is the car turbo or Non?
Old Feb 28, 2010 | 08:51 AM
klod622's Avatar
non turbo
Old Feb 28, 2010 | 08:57 AM
OK then the denso sensor is correct. How fast does it come back?
Maybe try to disconnect the battery for like 10 minutes to reset the ECU and see if the code stays away.
You will need to make sure you have the radio code before disconnecting the battery though.
Sometimes it takes the ECU a while to see the new part is in there.
Old Feb 28, 2010 | 09:09 AM
klod622's Avatar
it comes back on the second time i start the car. ill try disconnecting it again see what happens.
i disconnected it again for over 10 minutes and it came right back on.
Old Feb 28, 2010 | 10:16 PM
s70_t5_1999's Avatar
have you driven the car for at least 10 minutes? when i replaced my coolant sensor it took ten minutes for it to "recognize" it and turn the cooling fan off....
Old Mar 1, 2010 | 01:40 AM
klod622's Avatar
yes, i have driven the car almost 1000 miles since changing it.
Old Mar 7, 2010 | 07:54 AM
volvos701999's Avatar
I had the same problem with the CEL. A mechanic friend told me to disconnect the negative battery terminal and then turn the headlight switch to on -- leave for 10 minutes and it worked.... maybe I was lucky.....
Old Mar 7, 2010 | 12:17 PM
klod622's Avatar
yea tried that too, it wasn't the issue here but got it off by disconnecting it and recounting the o2 sensor. im a chevy guy theis volvo stuff is throwing me off.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
colgate41
Sep 14, 2005 11:20 PM
jclark50
Mar 18, 2005 09:59 AM
robohopar
Jan 11, 2005 05:32 PM
