99' S70 T-5 | Looking for solutions to problems SMALL RADIATOR FLUID LEAK
Old Nov 2, 2011 | 11:01 AM
cardrumS70's Avatar
Question 99' S70 T-5 | Looking for solutions to problems SMALL RADIATOR FLUID LEAK
My s-70 has about 184K on it. Over the past 6-7 months I have noticed a very small leak, as I have had to put coolant into the overflow. Its gotten worse where I have to fill it sometimes twice a day. Since it's cooler outside it doesn't need to be feed as much.
I had a buddy tighten up one of the hoses that seemed a little loose, but I am still having issues.
Old Nov 2, 2011 | 12:27 PM
If the radiator is leaking replace it. Just not worth destroying the car over. If you're not sure where it's leaking, check under the timing belt cover to make sure it's not your water pump. If it's not that, have the rad pressure tested. If it's leaking, replace it with one from a good source, someplace that sells Volvo parts all the time. NOT A RAD FROM A SALVAGE YARD.
Old Nov 5, 2011 | 11:04 AM
cardrumS70's Avatar
Absolutely. There is also a coolant smell that I have been getting in the cabin, sometimes there is a steam that comes through the vents, does that provide any more clues as to the root cause?
Old Nov 5, 2011 | 11:20 AM
Likely the heater core.
https://volvoforums.com/forum/volvo-...r-vents-58306/
https://volvoforums.com/forum/volvo-...acement-25511/
Old Nov 5, 2011 | 11:37 AM
cardrumS70's Avatar
Yeah. I was just doing some more research and several things lead me to believe this. Thanks for your information. Would you recommend a junk yard to save money? Or strictly new?
Old Nov 5, 2011 | 01:30 PM
NEW. I don't think they cost that much.
irm
Feb 22, 2012 08:11 AM
vol
Aug 3, 2011 09:31 PM
jmallie
Jun 10, 2009 10:05 PM
flyingcurtains
Sep 27, 2005 09:06 PM
