99 S70 T5 Whistling
Old Dec 30, 2008 | 08:23 PM
prime81's Avatar
Default 99 S70 T5 Whistling
Just figured I'd go ahead and post this up...
It whistles right after it starts for around 3-5 secs then disappears, and it's intermittent so it does not happen everytime. I have changed the tbelt, idler pulley, tensioner, plugs, serp belt is good.
Any ideas?
Old Dec 31, 2008 | 07:56 AM
Default RE: 99 S70 T5 Whistling
Does it only seem to happen when the A/C is on?
Old Dec 31, 2008 | 12:14 PM
prime81's Avatar
Hrmmm good question, I will test and see.
Old Dec 31, 2008 | 07:34 PM
prime81's Avatar
Nope it did it today with A/C off... it's very intermittent and doesn't seem to effect performance.
Old Jan 1, 2009 | 08:02 AM
As long as you did not have the defroster on that rules out a bad Orifice tube for the A/C.
Or I wonder if you have a small vacuum leak.
Old Jan 1, 2009 | 08:47 PM
prime81's Avatar
Ok today I noticed it was doin it after I shut the engine off, I also noticed this morning I turned the AC button off, and fan control to off which disables the entire system and started it up and it did not whistle after startup or warming up for 5 mins, but as soon as I turned on the fan control it whistled.
So I'm thinking a fan or blower of some sort, or perhaps the AC compressor.
Old Jan 2, 2009 | 07:18 AM
Was it on defrost?
If so then the Orifice tube in the A/C line just outside the passenger side firewall.
Old Jan 2, 2009 | 07:23 PM
prime81's Avatar
Well if the auto setting puts it on defrost then yes it could have been, but I have not turned defrost on this year yet as it has not iced over yet.
Old Jan 2, 2009 | 09:16 PM
Hard to say you would have to see if the compressor is cycling.
SDozier
Mar 19, 2011 03:43 PM
datastreamcom
Aug 20, 2007 11:23 PM
volvo94404
May 25, 2007 06:49 AM
frontsight
Apr 16, 2006 04:35 AM
danielribo
Oct 23, 2005 06:38 AM
