AC Makes Loud Sound When I turn it on
Old Jun 4, 2008 | 04:33 PM
Python138's Avatar
Default AC Makes Loud Sound When I turn it on
Hello, I have a Volvo S70 T5 1998 and when I turn on the AC it makes a loud sound and the sound gets louder if I increase the AC slider to MAX. It also smells something like burnt rubber when I open the hood. Any Ideas? Thanks, Jim
Old Jun 4, 2008 | 09:07 PM
jsj_297's Avatar
Default RE: AC Makes Loud Sound When I turn it on
Hey Jim, with those exact symptoms, I would pull off accessory drive belt and check. Could be belt slipping on the A/C clutch pulley causing noise and burnt rubber smell. Maybe assy. belt tensioner not giving enough pressure for the belt not to slip too. I take it you are getting squeeling type noises? Does it stop when a/c is off?
Old Jun 5, 2008 | 08:14 AM
Python138's Avatar
Hi jsj_297, Thanks for replying. Yes, if I turn the AC off the sound goes away. The weird thing is when it first happened I was driving home and it made the car kind of sutter so I turned off the Radio then the air and as soon as the air was turned off I was fine. I am hoping it will not cost an arm and a leg to repair. Once I got it home I popped the hood and turned the air to low and could hear an awful grinding noise but I don't know where it is coming from. So thenoise itself is more like a grinding. Too bad this site doesn't take videos as I have taken a video of it.
Old Jun 5, 2008 | 10:36 AM
jks2's Avatar
Sounds like maybe your AC Compressor is going bad. Not sure how expensive a fix it is but as with any Volvo it wont be cheap.
Old Jun 7, 2008 | 07:55 AM
Python138's Avatar
But another notch in your belt!! AC Compressor was the problem and it was expensive. Thanks for the GREAT info!!
Old Jun 7, 2008 | 09:19 AM
archangel4's Avatar
'ow expensive?
LOVEvolvos
Apr 24, 2012 10:36 PM
trackstar
Jan 23, 2012 10:26 PM
XC90 Help me please
Oct 20, 2010 03:19 PM
lotusing
Jul 17, 2009 10:05 PM
iluvmyS60
Apr 23, 2008 07:32 PM
