Adding Factory Foglights
Old Jul 3, 2024 | 11:15 PM
Psaboic's Avatar
Default Adding Factory Foglights
Car is a 98 S70 GLT without the factory foglights. The wiring for the lights is there at the bumper and for the switch behind the blank off plate. So, aside from the obvious foglight assemblies grilles, and foglight switch, what else would I need to pick up to add working factory foglights. I'm assuming just a headlight relay.
Thanks in advance
Old Jul 4, 2024 | 12:50 PM
firebirdparts's Avatar
I guess you know the 98 is the last year with a bank of relays under the dash. Which is good. they used a relay, a real one, at the upper left corner of that array under the dash. I guess everything else is present. In the US, power comes off the main headlamp relay, and I it looks like they're all the same. As you know, this only has power on it when the headlights are ON and low beam.
The wiring diagram in this case shows USA as a variation on the "standard" diagram.
When I look at the wiring diagram, I see where there may be a jumper in there that accommodates variations in the light switch (not the relays) used in different countries, and I have seen this jumper on the 850's. It was mounted in a relay box but it didn't have a relay in it. I can't find in the diagram manual where this jumper is located. So I am mildly concerned about that might be missing.
Old Jul 4, 2024 | 12:54 PM
That item 34/13 is what I am wondering about. I looked and couldn't find anything saying where it goes.
Old Jul 5, 2024 | 04:50 PM
Psaboic's Avatar
Hmmmm.
Rockin' Kat
May 31, 2013 12:42 AM
bananacar
Apr 15, 2013 05:23 AM
air force rascal
Oct 22, 2009 08:30 AM
Carrots
Jul 12, 2009 03:17 PM
S70ESQUE
Dec 8, 2007 04:15 PM
