adding OEM fog lights... help!
Old Jul 11, 2009 | 08:21 PM
Carrots's Avatar
Default adding OEM fog lights... help!
I'm trying to add a pair of factory fog lights to my '98 S70 GLT. I found that all the wiring appears to be there already. I got a pair of lights, the switch, and the relays (one of which is simply a jumper!) all from the same car at a salvage yard, connected everything, and... they don't work. What am I missing? does something need to be programmed? is there an additional part I need to get that I didn't see in the wiring diagram? Any help would be appreciated
Old Jul 12, 2009 | 08:54 AM
Did you also get the headlight relay?
Old Jul 12, 2009 | 01:08 PM
Carrots's Avatar
Ahh... different headlight relay. Of course. Okay... I'll go get that, too. Thanks!
Old Jul 12, 2009 | 02:26 PM
Carrots's Avatar
Okay... got the headlight relay from the other car, swapped them out, and... they work! Thanks, Tech!
Old Jul 12, 2009 | 03:17 PM
Glad all is good now.
Rockin' Kat
May 31, 2013 12:42 AM
bananacar
Apr 15, 2013 05:23 AM
GTO 06
Jan 28, 2011 07:59 PM
mdirollo
Jul 17, 2008 11:36 PM
flyboy
Oct 10, 2005 08:17 PM
