air pump/check engine
Old Mar 24, 2009 | 02:54 PM
cestan's Avatar
Default air pump/check engine
check engine light came on. took it to auto zone they pulled code for secondary air injection system. pulled air pump. full of water and dead. replaced pump, replaced relay and replaced valve. will the check engine light go off by itself? or do i need to do something. i do not have access to the code reader thingie
Old Mar 24, 2009 | 07:49 PM
You need to have the codes cleared.
Old Mar 24, 2009 | 10:00 PM
Johnny Mullet's Avatar
It is supposed to clear itself after so many drive cycles without a fault, but not always. Disconnecting the battery for 10 minutes works also, but then you need a radio code.
Old Mar 25, 2009 | 07:15 AM
FredMc's Avatar
disconnecting the battery does not clear a code.
the codes need to be manually removed, they will not go away
Old Mar 25, 2009 | 08:07 AM
cestan's Avatar
thank you. could someone suggest the cheapest code reader i can buy that will remove the codes. i know nothing about them so the specific name and model number would help. thank you. without the help here i do not think i would have taken this project on. i learn something new everytime i log on here.
Old Mar 25, 2009 | 08:09 AM
cestan's Avatar
forgot to say it is a 1998 s70 glt. when the codes are cleared will the check engine light go off?
Old Mar 25, 2009 | 06:39 PM
Yes when the codes are cleared the light will go off.
Try Auto Zone and see if they will clear them.
Old Apr 15, 2009 | 12:26 PM
cestan's Avatar
interesting. replaced air pump, relay and check valve. check engine light went off by itself. pump is noisy but i think this is due to the old pump being mounted with rubber and the new one did not have the screws attached to rubber connectors. probable need to put some rubber washers between the air pump frame which attaches it to the car? also pump seems to turn on intermittently when the car has been running and is warmed up already. i hear it when i first start the car and then it goes off when the car is warmed up. is there a temperature sensor somewhere which need to be replaced?
xDread92x
Jun 8, 2014 08:12 PM
turboxr
Dec 17, 2011 12:35 AM
vjaneczko
May 3, 2010 07:35 PM
jordaninabox
Aug 17, 2008 11:03 PM
Axis
May 3, 2007 04:03 PM
