Battery drains
Your post is a little confusing.
You charge the battery and drive the car off and on for 3 days and the battery is always dead at the end of 3 days?
or
You charge the battery, drive the car around, park the car for 3 days and the battery is dead at the end of the 3 days?
The former is an alternator issue
The latter is a battery issue or a parasitic drain on the battery
How many miles on the car? 97
or
Hi Everyone, thanks for the help, sorry if my post was confusing, just to clarify. If I leave the car for 3 days & then try to start it, battery is dead. If I then charge the battery or start the car with jump leads, everything is fine, car starts, runs ok,& I can use it without a problem. Then I go off to work in the van for 3 days, come home & car battery is dead.
Seems like this parasitic drain, I'll try to get hold of a load tester & go from there. The car has done 240,000kms, looks like the original alternator. Also thanks for the step by step! I'll try it
You don't need to get a load tester.
Always test the battery first. It's the easiest thing to do. Pull it, take it to a parts place. They will load test it for free for you. Takes 1 hour. (Make sure you have the radio code before pullinghte battery).
After that, all you need is a multi-meter. Follow the video, it's very good.
Hi, Goodish news, the faulty circuit has been located, just got to pin the actual fault down. Turns out it is the central locking cct. Thought I would leave the fuse out until I could find the problem, only thing is, I can't start the car with the fuse out! Seems the central locking cct is linked to alarm/immobiliser cct. Any thoughts welcome;
I'll keep plodding on
BAZK sw France
BAZK sw France
BAZK sw France
BAZK sw France
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
So let me guess (again); bet your interior light switch setting, where the lights go on/off when you open/shut the door(s), didn't work, yes?
Oh yeah, and at 0.02A (20 mA) you battery now won't be dead in 3 days. Maybe 3 or 4 weeks, but not 3 days.
#17
Oh Dear ! The problem has gone! Checked the draw first thing this morning(0.02a) with all of the drivers door switches and door panel switches disconnected. In turn I put the connectors back on and then checked the reading each time. After every connect & check, the draw started out at .75a and once the int lights went out it settled done to 0.02a.I've done the whole connect & disconnect of all door fitments twice and the fault hasn't come back And that is where it is now. So looks like "keep a spare charged battery & jump leads in the car" & wait for next time!!
BazK, very mild sw France.
#18
#19
shrinking
06-09-2015 09:22 PM
