Which Belt?
Old Jan 29, 2009 | 08:49 PM
jayturk99's Avatar
Default Which Belt?
I need help on which timing belt to purchase for replacement. 1998 S70, want to get belt replaced but I have two options, eng #1266128 or #1266127. I thought the correct number would be on the timing cover but it's not, any suggestions? Thanks.
Old Jan 29, 2009 | 09:01 PM
Sorry to say but we will need a little more info to be able to tell you which one you will need.
We need to know if you have a manual tensioner or a hydrolic tensioner.
The 1998 was a split year for the 2 different belts.
Old Jan 30, 2009 | 08:37 AM
placer61's Avatar
Jayturk, Actually, you should look for an engine number UP TO 1266127, or OVER this number to determine which belt kit you need. You probably don't have either of the two numbers. If you don't have the sticker on the timing cover, the other way to determine which to use, short of removing the cover and checking the tensioners (best way), is the type of ignition system you have. Tech can give you hints on what to look for better than I can.
Old Jan 30, 2009 | 04:28 PM
jayturk99's Avatar
Thanks for the help fellas, I had to take the timing cover off will at a Volvo shop and had it identified. It was a hydraulic tensioner. The guy suggested I change the pulleys if once the belt is off they have a problem turning. The mileage is at 213k, last t-belt change was at 140k, he also suggested to not change water pump since it was not leaking. Does any of this sound legit??
Old Jan 30, 2009 | 04:34 PM
I would do the pulleys no matter what.
If the pump is not leaking I would leave it. But thats just me I can do the job in no time as well.
manoduv
Oct 24, 2013 12:22 PM
reedkm
Sep 22, 2009 07:42 PM
schoolloans
Jun 18, 2009 08:34 PM
boulwie
Dec 23, 2007 11:41 AM
ko_kidd
Aug 25, 2006 08:53 PM
