blend door motors
1998 S70 GLT
I have the dreaded ECC blinking lights.
AC on there cold air on the left and warm air on the right thru whatever vents I switch to.
Heat on there is cool air on the left and hot air on the right thru whatever vents I switch to.
The blower motor is strong.
There are no odd noises anywhere.
I do not know if I should, but I feel nothing with my hand on the right motor as I minipulate the controls. Should I?
I have done numerous searches and have yet to find a definitive answer to the following questions.
Does the left side motor singuralry control the left side only?
I see the stub on the right motor rotating w/a change in which vent I choose.
The climate control sensor appears that the motor is not rotating. I have shot the sensor w/canned pressure and it appears fairly clean.
So, big question:how do I diagnose in a linear way to solve this issue?
Thank you and all replies are welcomed,
Tommy
Tommy
The climate control sensor was unplugged when the scan was done.
With all these codes, why do I have what I posred?
![](https://cimg2.ibsrv.net/gimg/volvoforums.com-vbulletin/1500x2000/img_20211017_174441755_52a062a6ecaf51ca64167efd12bf739ae1f8e46a.jpg)
