Brake pad suggestion
Old Aug 18, 2009 | 01:53 PM
thekoopa's Avatar
Default Brake pad suggestion
Going to buy new brake pads soon and I was searching through threads on here to find what people recommend and it seems everyones opinion is different. I have ceramic pads right now and they squeal at low speeds. I don't really remind the brake dust because I wash my car at least once a week and I have black rims. I saw some organic pads on IPD and they don't look that bad but I just wanted some opinions before I spend the money. Thanks.
Old Aug 18, 2009 | 02:57 PM
daironman's Avatar
I've stuck with the ceramics...I get a little squeaking when backing up, none going forward. I had organics and I don't think you get as much stopping power out of them. PLUS...the dust!! Squeak doesn't bother me too much to want to switch them out...
Old Aug 19, 2009 | 07:35 AM
Carrots's Avatar
Avoid organic pads. Yes, they're quieter, but there's a reason Volvo didn't use organic material. They don't stop as well, and they wear out super- fast. Any good quality semi- metallic or ceramic is a good idea. Want to get rid of noise? thoroughly clean all surfaces that the pad touches- caliper piston, caliper inside, and the caliper bracket where the pads ride. Lubricate the caliper slides with grease intended for that purpose, then use some kind of anti- squeal compound- I prefer the spray- on type- and coat the back of the pads. If you still get squeal, you can bevel the edges of the pads, then recoat with anti- squeal compound. Good luck.
Miatamon
Jul 27, 2011 02:29 PM
freddie
Aug 19, 2007 01:31 PM
marvyndt
Jun 21, 2007 09:48 AM
Sidney03
May 28, 2006 08:06 PM
mphubbar
Aug 12, 2005 01:28 AM
