brake pads renewal help please
Old Mar 31, 2012 | 12:31 PM
marco0909's Avatar
Default brake pads renewal help please
hi im not a mechanic.
thought i would do my brake pads myself.
where do i start? which bolts do i take off to get the caliper off?
im doing rear and front. ive watched plenty of videos and they dont seem clear as to what bolts you remove. and do i need an allen key? thought it was all bolts .
Old Mar 31, 2012 | 09:52 PM
This is how I did it:
Brake pads, front, replacement instructions on a 1998 S70 Volvo, also 850
Some use a allen wrench to do the job which may be a little easier. Took the caliper apart instead of taking them loose.
Old Mar 31, 2012 | 10:36 PM
bizzy102's Avatar
get a breaker bar handy, 3/8 size.. Just in case they are stuck. Use some lithium grease when u go back..
Old Apr 5, 2012 | 06:17 AM
Huh? Lithium grease for what? You would rather use loc-tite than grease. You DO NOT want your brake bolts coming loose.
Old Apr 5, 2012 | 09:40 PM
Lifesgoodhere's Avatar
you need
a jack
a 19 mm 1/2 drive socket and 1/2 drive breaker bar for the lug nuts (assuming you do not have access to air tools -- air tools make it go faster and easier)
3/8 ratchet with 7mm hex socket (cheater bar might be needed might not)
anti-seize
large screw driver to remove and install the outer spring
large channel locks to push the piston back in.
1 can of brake-cleen and a rag
after awhile you get the routine down to a 15 minute art form. In, up, down, out, done.
Old Apr 5, 2012 | 09:43 PM
lock tight....ewww I hate the stuff, if its something I know won't need to be serviced for a vary long time I use it, but on brakes where every 30-50k miles they are tore into anyway putting lock tight on just makes it a pain for the next time or unfortunate person to deal with.
I have yet to see a correctly tightened caliper pin just fall out because lock tight wasn't put on it.
Old Apr 6, 2012 | 03:56 AM
I never use the stuff, you can see that from the instructions I posted. However, I think most manuals call for it. My point was that you would rather use loc-tite than anti-seize when installing caliper bolts.
Old Apr 6, 2012 | 05:53 AM
well, you need to put anti-seize on the pins and getting some on the threads will actually prevent galling the threads when you put them back in and also the next time they come out.
Old Apr 6, 2012 | 06:48 AM
So you guys put anti-seize on caliper bolts at your shop?
Old Apr 6, 2012 | 08:29 PM
no on the pins, smear a dab on the surface and sometimes a bit gets on the threads, which if no big deal and doesn't harm anything.
if the caliper pins are really bad, we actually run them on the wire wheel for a second and them resurface them with 320 grit emery cloth.
ibified
May 22, 2011 08:35 AM
navypilot9
Jan 30, 2011 10:15 AM
MattS77
Dec 19, 2007 10:31 AM
thullz
Nov 7, 2006 09:25 AM
Flying torquewrench
Jun 24, 2005 06:11 PM
