Brakes:- Rotors and Pads question!!!!
Old May 1, 2006 | 08:32 PM
Gusto's Avatar
Default Brakes:- Rotors and Pads question!!!!
Hi Tech again, I have a question regarding my brakes. I need to have both my pads and rotors replaced; something I 've been putting off for a long time now! I hear sqeeking sounds before which it was just a lot of grinding. Took it to 3 different repair shops and all narrowed to replacing all teh way rounds front rotors w/ pads, rear rotors w/ pads. My question is, what would you recommend for my vehicle (99 s70 awd non turbo). I keep coming across brembo, pbr rotors and slotted rotors. I just don't know much about volvo brake replacement parts and ofcourse the dealer is my last resort. Also what about mintex pads? I guess, I'd like some advice on what to get for my needs which are; less brake dust as possible, long lasting and a good peformance all the way round. I need to do this ASAP as I can tell that it's taking me a while to come to a complete stop and really need to get this fixed. Anybody can reply and tell me your experience with your new rotors and pads and what you prefer or recommend.
I appreciate your help....Thanks!!!!!
Old May 1, 2006 | 09:04 PM
JimKW's Avatar
Default RE: Brakes:- Rotors and Pads question!!!!
There are quite a few threads on this board where people recommend various brake parts. The most consistent problem with anything but OEM is squealing. I have tried aftermarket brake pads and went back to OEM and that's all I use. It gets my wheels dirty, but it stops my car and no squealing. Tech likes the OEM also, but others highly recommend some other brands. Do a search and find what others say. I'm pretty sure REG has some brake recommendations just recently, but I can't remember what he said he has been using for years.
Old May 2, 2006 | 09:31 PM
Gusto's Avatar
Thanks Jimkw. I wasn't too sure about the OEM pads but I guess they would've have to do for now. And what about the rotors; should I go with the OEM discs for both the front and rear? Who has better prices that you can think of? thanks.
Old May 2, 2006 | 09:37 PM
At work we use OEM pads and Brembo rotors. They are cheaper than OEM and work well with the OEM pads.
Old May 2, 2006 | 10:51 PM
Gusto's Avatar
ORIGINAL: tech
Tech, thanks for your response. okey quick question; what's the difference in the rotors because I found slotted and/or cross drilled every time I search. Which ones do you think ared better drilled or not?
Old May 2, 2006 | 11:06 PM
The drilled stay cooler and release gasses from the pads while braking.
The solids get hotter.
But buy what you want.
Old May 3, 2006 | 12:06 AM
Gusto's Avatar
Ok Tech. I appreciate you a whole lot you are the "Tha Man". I think I'll go with the OEM pads and perhaps the brembo drilled rotors. Am checking out prices right now.
Thanks a gazillion and keep up the good work.
Gusto
grndslm
Jun 30, 2012 02:44 AM
Jabber
Dec 21, 2010 11:16 PM
madphill
Jan 20, 2009 08:31 PM
andrewgrhogg
Sep 22, 2005 10:23 PM
indagutter
Jan 5, 2005 01:57 PM
