Can I replace throttle from turbo to non-turbo, S70?
Old May 15, 2017 | 10:20 AM
lucianic1's Avatar
Default Can I replace throttle from turbo to non-turbo, S70?
Hi,
I have a Volvo S70 2.4l 1999 and I have some codes P1031 & P1026. The engine at idle shake so I believe my throttle has to be changed.
I found a second hand one from a S70 2.4l turbo 2001. I found only the number between the code bare almost similar. Mine is 8644347 65CFM-2 and turbo one is 8644345 65CFM9.
I have to buy it and my question is if it is compatible with mine?
Thank you very much
There is people that still love S70 and one of them is me
Old May 18, 2017 | 08:54 PM
lucianic1's Avatar
Default doesn't work
I tried but did not worked. The idle goes very high (4000 rpm) without any action. The software could be the problem.
Old May 19, 2017 | 12:25 PM
Smith Volvo's Avatar
Banned
The ETM is that same part number - but they are programmed to the vehicle. Your best bet economically would be to send your defective one to XeModex and have them repair yours
Ablorx
Jul 4, 2014 08:33 PM
Ablorx
Engine & Internal
Jun 24, 2014 09:44 PM
volvo_s70
Mar 9, 2009 08:38 AM
