changing oil and trans fluid question
Old Dec 26, 2008 | 11:46 AM
cdurnal's Avatar
Default changing oil and trans fluid question
what kind of oil should i be putting in?
Old Dec 26, 2008 | 06:18 PM
FredMc's Avatar
Default RE: changing oil and trans fluid question
I have a question too...
What type of car, mileage, year and prior oil usage?
Generally if it's a turbo, then use synthetic oil 5/30 but opinions will vary, and use a Mann filter or NAPA gold.
Trans oil depends on transmission, read the owners manual for the proper grade, usually cars 98 vintage and older use Mercon/Dexron III. Newer cars with 5 speed autos use Mobil 3309 or Toyota T1V, or Volvo Dealer fluid. All the same stuff, price is expensive at Volvo Dealers though.
Old Dec 29, 2008 | 01:42 PM
prime81's Avatar
I bought my 99 S70 with 60k miles few weeks ago, no clue as to what oil went in it before it was mine. So I ended up reading the owners manual and went with Castrol Syntec 10w30. Volvo does recommend Castrol oils in their cars. The general consensus I gathered was if your temps in your area get below -5 degrees fahrenheit then go with 5w30, otherwise go with 10w30. I ran my 97 850 GLT on Castrol GTX 10w30 for around 5 years, and it was bought with 85k miles on it, never had any issues.
I do know syntec can sometimes burn a bit for the first few changes if switching from a dino oil because it cleans out junk leftover from the dino oil.
Volvo_Neps
Nov 11, 2013 10:12 AM
mike1973
2001-2013 model year XC70
Oct 29, 2013 08:49 PM
537playing
Nov 12, 2011 03:40 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
novablue69
Dec 24, 2005 02:53 PM
