Chasing mysterious Oil Leak BELOW Timing Belt area
Old Jan 27, 2010 | 08:49 AM
cn90's Avatar
Default Chasing mysterious Oil Leak BELOW Timing Belt area
Chasing mysterious Oil Leak BELOW Timing Belt area.
- Car is 1998 V70 is now 105K miles and runs fine, no problems at all.
- TB and Hydraulic Tensioner changed in 2004 at 60K using Contitech TB and OEM hydraulic tensioner (Pulleys x 2 not changed at 60K).
- I just removed the TB cover for an inspection and saw minor (maybe a few drops of oil) in the area just below the hydraulic tensioner area as shown. It may or may not be important so I need advices from the pros!
- I used a mirror and flash light and observe that:
1. Hydraulic Tensioner: bone dry, no evidence of leak, even with my hand sweeping around it.
2. Areas BELOW Cam seals and Crank seal are bone dry!
3. Minor oil on the INNER CV Boot (which is directly below and behind the TB area)
4. Water Pump: Bone dry.
5. TB is nice and tight and no grease coming from the 2 pulleys at all.
Three months ago, I saw this minor oil leak and spray-cleaned it and now it re-appears!!! I am puzzled as to the source of this oil leak. Any ideas?
Thanks!
Old Jan 27, 2010 | 10:40 PM
gdog's Avatar
Is there any oil in area directly below the oil trap; passenger side front lower part of engine?
If so, likely hoses on oil trap leaking and blowing around to TB area.
Old Jan 28, 2010 | 04:06 AM
Is there any evidance of oil anywhere else? Wipe everything down and check it in a week.
That timing belt set-up looks very simular to the 960 layout.
67fairlane500
Jul 4, 2022 08:06 PM
ThomasK
Jan 25, 2012 08:56 PM
panaphs
May 1, 2011 01:36 AM
cn90
Jan 28, 2010 10:14 PM
MMAFIGHTER
Oct 9, 2008 11:21 AM
