Check Engine Light
Old Jul 18, 2006 | 05:42 PM
DaveNY's Avatar
Default Check Engine Light
I have a 1999 S70 with 134K miles. My check engine light came on today. The owners manual says its related to a fault in the emission controls system. Any ideas?
Old Jul 19, 2006 | 12:28 AM
Default RE: Check Engine Light
You need to have the Codes pulled to find out what was wrong.
Old Jul 19, 2006 | 09:56 AM
DaveNY's Avatar
Tech, I might be selling the car in the near future so I don't want to put the money out for the repair at this particular time. My question is. If I continue to drive the car with the check engine light on am I at risk of doing damage to the car?
Old Jul 19, 2006 | 09:41 PM
Depends on what is wrong did you get the codes pulled yet?
Old Jul 20, 2006 | 09:27 AM
DaveNY's Avatar
I didn't have the codes pulled yet. Is there a method for me to pull the codes myself or do I need a technician to pull them for me?
Old Jul 20, 2006 | 02:54 PM
DaveNY's Avatar
This is kind of weird. I went out for a lunchtime ride and the check engine light came on when I started the car and then went off just it's suppose to. Maybe the check engine light itself had a glitch in it. Not sure what happened but the check engine light is no longer staying on.
Old Jul 21, 2006 | 12:06 AM
The codes are still there.
Do you live near an Auto Zone?
If so they can pull the codes.
Old Jul 21, 2006 | 08:56 AM
DaveNY's Avatar
I'll stop by the Auto Zone here to see if they can pull the code. Thanks.
Old Jul 30, 2006 | 01:41 AM
troytown's Avatar
this messege is for tech...i have just purchased a 98 s70 for my wife.it has 145000 miles on it.the timing belt has been changed,full brake job and new tires.
it now is having a/c problems. when you first crank the car,the air blows cold.after a little while it stops blowing cold.a freind of mine is a g.m. mechanic and
tested the freon levels which checked out,he did the screwdriver to the clutch and it was magnetised..he then checked the alternater and on full load it dropped in the 9,s.he is saying that it is probably the alternater not giving enough juice to keep the electro-magnet engaged?then the car started missing today and the check engine light came on! do these problems sound normal?i just dont want to replace the alternater when it is actually the compresser.i paid 3,000 for this car and the body,paint and interior is in perfect shape. please help man,my wife is about to kill me for talking her into buying this car
Old Jul 30, 2006 | 11:52 AM
The compressor Gap it to Large.
I would say the compressor is bad.
The Alt. dropping into the 9's might be another problem as well.
I would start with the compressor first.
Does the Alt. charge good with the A/C off?
Did you have the codes pulled for the light yet?
It might just need a tune up.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
