Check Engine Light Illuminated
Old Jun 20, 2011 | 11:32 PM
talbotpj's Avatar
Default Check Engine Light Illuminated
Hi,
I am the owner of a '98 S70 with about 142,xxx miles on it. A few months ago, the check engine light came on. The codes are as follows:
P0172-System Too Rich Bank 1
P0300-Random/Multiple Cylinder Misfire Detected
P0302-Cylinder #2 Misfire
P0303-Cylinder #3 Misfire
P0304-Cylinder #4 Misfire
P0305-Cylinder#5 Misfire
My initial reaction was to do a tune-up. I replaced the usual plugs, wires, cap and rotor. No help. Keep in mind the only noticeable symptom is a rough idle. The idle speed is usually 500-1000 RPM too high, but it then drops back down to normal after a few seconds. I do not notice any loss of power or misfiring while accelerating, although I'm not sure I would really notice anyway.
Any others ideas?
Thanks,
Pat
Old Jun 21, 2011 | 07:52 AM
Low fuel pressure? Restricted fuel filter?
Old Jun 21, 2011 | 08:55 PM
talbotpj's Avatar
This forum must be magical. After 6 months of having a CEL and many hours troubleshooting, the problem was solved a day after joining this forum! It was a broken vacuum hose the I had never noticed.
Old Jun 22, 2011 | 05:08 AM
silverstreak98's Avatar
Yes I agree this forum does help.
I too have a CEL light that comes on and off intermittently for the last 2-3 weeks
Popped the code - P0172-System Too Rich Bank 1 (just one code)
I would like to check my vacuum lines - is there a link or diagram to show where all the hoses are??
THANKS!
1998 S70 N/A
Old Jun 22, 2011 | 11:43 AM
donf's Avatar
There are many, here is one I found while looking for a leak.
http://i105.photobucket.com/albums/m...se-routing.jpg
jpravi8tor
Aug 28, 2017 05:35 PM
R3TRI8UTI0N
Aug 16, 2013 11:19 PM
104octane
Jun 11, 2009 03:04 PM
104octane
Engine & Internal
Jun 11, 2009 03:01 PM
parmbrust
Sep 20, 2007 12:51 AM
