Code P0410
Old Jul 31, 2009 | 10:44 AM
Trace's Avatar
Default Code P0410
My check engine light came on a cpl days ago so i took it
to autozone and had them hook the obd up, pulled the code
p0410....which is a "secondary air supply fault" they say.
they gave me hints like 'bad circuit connection' 'faulty air pump'
'bad sensor' ...does anybody have any experiance with this
"secondary air supply"? and where do you think i should start?
Thanx guys
Old Jul 31, 2009 | 06:15 PM
blackbrick's Avatar
maybe this can help you:
http://www.obd-codes.com/p0410
Old Jul 31, 2009 | 07:18 PM
Trace's Avatar
Default Thanx Blackbrick
That definitely helps me out man, a lot! The only thing is that
the link suggests that i replace the 'air pump',,,which costs
around $350. I definitely cant afford it right now. and i have
a 2000 mile trip planned in under two weeks. is this something
that will cause more expensive and permanent damage to my
baby?!?!?
thankyou!
Old Jul 31, 2009 | 08:20 PM
blackbrick's Avatar
Have you check air pump fuse?
I am not expert in any way but I think this problem affects only emissions not engine so I wouldn't worry for now. If emissions test is needed to register car then you will need to address this problem.
Old Aug 1, 2009 | 09:17 AM
bigdummy's Avatar
When the car is below 94 degrees start it up and listen for the pump to come on for 2 minutes or so.
If the pump runs the the vacuum valve may be bad. mine would not open with vacuum applied.
to test i just used the vacuum line that fed the solenoid that activates the airpump check valve.
Good luck
Old Aug 1, 2009 | 01:57 PM
Trace's Avatar
Default sweet,
Cool, I will do that tomorrow morning when it's not so warm out. so if
i open the hood where should I be listening at for the air pump? will
it be right there at the manifold? to be honest ive never dealt with
an air pump issue and didnt even realize that it had one! Thanx billions
bigD
Old Aug 1, 2009 | 02:24 PM
bigdummy's Avatar
It will sound like a household vacuum cleaner behind the passengers side headlight and near battery.
Bob in Dallas
Old Aug 10, 2009 | 06:45 AM
curtisckey's Avatar
Also check at the front center of the engine compartment, there is a vacuum line that connects there that can cause this fault if it becomes disconnected.
Fixityourselfer
Jan 4, 2016 08:57 PM
rob960
Sep 7, 2011 08:28 PM
Z06john
May 7, 2009 04:39 PM
safari
Dec 10, 2007 07:46 PM
BrianB1975
Jul 13, 2006 01:07 AM
