coolant light is on
Old Apr 13, 2008 | 12:21 PM
alireza1344's Avatar
Default coolant light is on
Hello there
I need some help. The coolant was changed out by dealer about 4 months ago. The reason was the coolant light came up, the overflow tank was empty and I had to add about 1 L. of water, just to keep it going before take it to dealer.
Again last night the coolant light came up and I check the overflow tank and it was empty. I have to add about a 1 L. of water (didn’t have coolant)
I checked the car and my garage there is no sign of leak. I wonder if anybody had the same issue before.
Also the coolant from dealer, does it need to be mixed with water or I can add it as is whenever it’s necessary? (till find the root cause)
Best
Old Apr 13, 2008 | 01:07 PM
Default RE: coolant light is on
The heater core might be leaking.
Not sure check the bottle Dealers use different stuff from Dealer to Dealer.
Old Apr 14, 2008 | 10:57 AM
Thanks Tech.
I know the heater core is a common problem, but I didn't have any issue with the heater, worked fine during the cold winter here in canada.
Also is there any way that I can check the heater core myself? I also heart about the pin hole in some RAD tubing.
is it the timeto replce all hoses in the car? asit is almot 10 years old and the rubbers mayhave developed some carck? what do you think, any recommendation? is it expensive
best
Old Apr 14, 2008 | 10:58 AM
Thanks Tech.
best
Old Apr 14, 2008 | 08:26 PM
Now when you turn the heat on do you get a sweet smell?
Old Apr 16, 2008 | 01:24 PM
No, no smell at all!! no leak on the ground either
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
