coolant light
Old Apr 3, 2012 | 12:07 PM
gotnadda's Avatar
Default coolant light
I have a 98 S70 T5 with 135k on it. After driving the vehicle for a while the low coolant light comes on during acceleration. When I check the coolant level the expansion tank is almost empty. There is also a gurgle noise sometimes and the smell of coolant. All the hoses were replaced @110K along with the expansion tank but the upper hose seems to be swollen. When I slowly release the pressure in the expansion tank all the coolant returns to the expansion tank and the coolant level returns to the max line. The t-stat was replaced at 92k. Is air being introduced into the system? Any advice would be appreciated.
Old Apr 4, 2012 | 07:19 PM
bizzy102's Avatar
Yup, u still got some air in it. Fill it, run it and shut it off. Wait about a 10 mins and check ur level. It should got down. Fill run and repeat till it is stable..
Old Apr 4, 2012 | 08:17 PM
If you don't have a green cap on the expansion tank go get one ASAP. Other than that, try not to take the cap off the expansion tank when the car is running or hot.
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
