Coolant type.
Old Oct 24, 2009 | 11:44 AM
thekoopa's Avatar
Default Coolant type.
Which coolant do you guys use in your volvos? I own a 98 s70 t5 and my low coolant light came on yesterday while driving home.
Old Oct 25, 2009 | 07:00 PM
texan_176's Avatar
Although it says Volvo coolant only I use Prestone standard stuff with distilled water in a 60/40 mix. Never had problems and the radiator is super clean.
Whatever you use be sure to flush and change it every few years. Oh and NEVER use tap water that contains minerals, flouride, and chlorine.
Old Oct 25, 2009 | 10:48 PM
Carrots's Avatar
Use any extended- life, silicate and phosphate free coolant. Standard Prestone or Advance auto parts brand meets these qualifications. Regular Peak brand doesn't- it has silicates in it. (which is bad for aluminum, and the radiator, head, and block on our cars are made from it) Extended- life Peak is fine.
Use a 50-50 mix with DISTILLED water. Minerals in tap water will cause crystals to form, plus they act as an electrolyte, which causes electrolytic corrosion of cooling system parts.
Old Oct 11, 2013 | 02:44 PM
Wildman
Dec 20, 2008 11:51 AM
Esnyder
Nov 6, 2008 09:41 PM
Crispin
Aug 26, 2007 12:04 PM
jollygoodgold
Jul 16, 2007 12:06 PM
Psaboic
Dec 1, 2006 04:53 PM
