Cooling Fan and Temperature
Old Mar 23, 2012 | 10:03 AM
tahawus's Avatar
Default Cooling Fan and Temperature
Hi all.
Been struggling with this one for awhile.
For the last few months, the temperaure gauge never reaches 3 o'clock. For twelve years, it's always been steady at 3. Car takes awhile to warm up and seems to be running cold. No CEL or codes present. Car runs fine; good gas mileage.
Assumed the t-stat was stuck open. Replaced it with a 90C Volvo t-stat...no change.
Recently, the cooling fan has been running after shutdown for about 3-5 minutes. Yesterday, turned the car to "ON" without starting it. Fan comes on (it's 50F outside).
Figured it was a bad fan relay. Replaced it...no change.
Any ideas? I haven't changed the engine coolant temperature sensor yet. Does the temp gauge get its data from the ECT?
2000 S70
Non Turbo
85,000 mi
Old Mar 23, 2012 | 06:50 PM
Henry Jones Junior's Avatar
I've been thinking I have the same problem lately. You're the first person I've come across who thinks it's there too.
Old Mar 24, 2012 | 06:51 AM
tahawus's Avatar
Default Fixed!!
Replaced the ECT sensor. That was the problem. The temp gauge quickly returned to 3 o'clock and held steady, the fan isn't running after shutdown on a cold engine.
One thing I thought odd...I never had any CEL code, but after replacing the ECT with one from Volvo I got "range error" (P0116). Reset the code and it hasn't re-appeared.
I can only guess that the ECM remembers the most recent value sent by the ECT. Upon changing the ECT, the ECM must have received a drastically different value (the correct one) and lit the CEL.
All is good now.
Wufpack
Aug 8, 2025 12:31 PM
norasaint
Sep 20, 2012 12:53 AM
The Dude Abides
Mar 7, 2011 09:33 PM
mtneyman
Aug 4, 2010 03:46 AM
elouadj
Jun 25, 2008 07:00 PM
