Cooling system problem
Old Dec 30, 2007 | 04:08 PM
SVNWGN's Avatar
Default Cooling system problem
Hi All,
Having a problem withthe cooling system on my S70. The coolant tank wont stay full but I cant seem to find where any coolant is leaking around the engine.
I can refill the tank and then drive between 30 - 40 kms and then the low radiator light comes on. It isnt over heating and i can drive over 100 k's with the light on and it only appears to drop the water in the bottle and takes about 1/2 to a litre to refill.
Please Help me, its driving me insane!
Cheers
Old Dec 30, 2007 | 06:41 PM
Default RE: Cooling system problem
Do you smell coolant in the car?
The heater core might be leaking.
Old Dec 30, 2007 | 07:19 PM
SVNWGN's Avatar
no smell of cooloant in the car, or any sign of coolant in the car. Have had the heater running to test that.
Old Dec 31, 2007 | 04:53 PM
Then you will have to find someway to pressurize teh system and check for leaks.
Old Jan 2, 2008 | 07:16 AM
RPMCanes's Avatar
Is it showing more white smoke than usual?
Old Jan 2, 2008 | 04:45 PM
ROBG's Avatar
Coolant reservoirs and heater cores often start as small leaks
that are difficult to diagnose. If you would like you can lift
up coolant reservoir and check around hose connections for
staining. Smaller hoseconnector is weak,so be gentle.
I hope this helps
Rob
Old Jan 8, 2008 | 01:28 AM
SVNWGN's Avatar
Thanks for all the ideas, found the problem.
One of the heater hoses that runs across the bottom radiator hosed a pin hole. Diddnt notice it cause the coolant was pooling on the top of the transmision and not leaking under the car. I found it when the car was parked on a funny angle and it ran off.
s70_t5_1999
Jan 22, 2010 11:53 PM
madhatter
Sep 1, 2006 01:15 AM
lenniefoug
Dec 4, 2005 11:30 AM
volvoslim1
Jul 20, 2005 08:12 PM
