Cruise Controll not working (need help)
Old Mar 6, 2011 | 03:27 PM
chuckdy12's Avatar
Default Cruise Controll not working (need help)
my cruisecontroll is not working. i checked teh fuse it still looks good. any suggestions?
Old Mar 7, 2011 | 02:27 AM
f88's Avatar
f88
how is it not working?
what if you turn the cruise control on, set it at a speed by using the "SET" button..
Then as you keep cruising your speed should drop as you say it's not working, then try pumping the accelerating pedal a couple of times quickly and see if the cruise control would start working again?
if it does, then the accelerator linkage, throttle body etc. are probably gummed up, let us know how the test goes...
Old Mar 7, 2011 | 01:38 PM
In the 850 models there is a common problem with vacuum lines.
Look here: https://volvoforums.com/forum/volvo-850-16/hot-topics-helpful-information-how-diy-repairs-26114/ item 27.
Big_White
Nov 25, 2014 10:04 PM
rspi
May 15, 2014 07:36 AM
reneweteling
Jun 12, 2011 05:09 AM
rspi
Mar 7, 2010 06:13 PM
rejeep
Oct 26, 2005 01:36 AM
