Cylinder 2 misfire
Old Jan 3, 2008 | 06:10 PM
d2jreality's Avatar
Default Cylinder 2 misfire
Got a code P0302 (cylinder 2 misfire) and cant figure it out. I switched out the ignition coil and spark plug, checked the injector o-rings (may need new ones). Compression should be good, (just had the head out and back in on suday). I drove it for a total at max 1 mile. Code keeps poping up. Its got a new intake manifold gasket, actually all the gaskets are new! Valves are straight as an arrow! Exhaust could probably be replaced but dont feel like dropping in new parts if its not going to correct the problem code.
Any suggestions? DidI miss something?
Thanks
Old Jan 3, 2008 | 07:06 PM
Eric J's Avatar
Default RE: Cylinder 2 misfire
Does it run rough and can you hear it putt out the exhaust?
If not, it just might have to be driven some to clear up,keep an eye on all the vitals.
Old Jan 3, 2008 | 08:36 PM
Did you do all the Valve work?
Spray around the intake with either carb or brake cleaner with the car running checking for a vaccum leak.
Old Jan 4, 2008 | 01:12 PM
d2jreality's Avatar
its running rough and it does putt. the valves were fine. at idle it sound almost perfect but when I drive it it runs horrible. check engine lite flashes and the turbo does not want to engage. I'll check the intake for leaks to see what happens.
thanks guys.
Old Jan 4, 2008 | 05:46 PM
I would still do a compression test.
I have seen valves ever so slightly bent and cause a problem.
Did you fill the combustion chamber with fluid and see if it leaked out the valves?
Old Jan 5, 2008 | 06:31 PM
d2jreality's Avatar
no, but the headwill be coming out again. i'll be sure to do that.
akirk6884
Dec 24, 2010 10:29 PM
neurorocker
Feb 1, 2008 08:54 AM
Febus
Oct 31, 2007 07:37 AM
postdoc99
Oct 11, 2006 01:12 AM
