Cylinder misfire, oil in #3
Old Jan 31, 2008 | 04:38 PM
neurorocker's Avatar
Default Cylinder misfire, oil in #3
Hey, car started running bad today (1999 Volvo S70). When the Check Engine came on, I ran the codes and it came up with a cylinder misfire and low catalytic. So, I bought plugs. In the process of replacing, I noticed a small amount of fresh engine oil in the number 2 cylinder. All others were clean. After replacing cylinders, car was running worse. Any idea what's going on?? I would really appreciate any input on how to repair or what I am looking at $$ wise if I go to a dealer.
Thanks,
Nate
Old Jan 31, 2008 | 04:42 PM
Please respond to this thread about cylinder misfire and oil in #3..I forgot to check the notify me by email when someone replies box. Thanks!! Nate
Old Feb 1, 2008 | 08:54 AM
JimKW's Avatar
Default RE: Cylinder misfire, oil in #3
You need to pull you codes via the odb-ii port and let us know what codes you are getting. Was there oil in the cylinder or just on the outside of the plug? Any oil laying under the spark plug cover?
akirk6884
Dec 24, 2010 10:29 PM
d2jreality
Jan 5, 2008 06:31 PM
Febus
Oct 31, 2007 07:37 AM
postdoc99
Oct 11, 2006 01:12 AM
