Dash board removal for mounting tab repair
I had 2 broken tabs. Removed the screws under the wiper plastic cover. Got a can of spray foam insulation. Inserted the tube into the screw hole and shot some foam in. The foam expands and hardens, no more squeaks.
Recently after damaging my dashboard I found a replacement at a parts recycle yard. Two of the tabs were broken off and a third was cracked. All the pieces were large and not missing. I used "plastic welding" to reattach the parts to the dash. Please search on the web for plastic welding. On youtube I found this video instructive,
There are other videos as well.
I purchased a 30 watt soldering iron from Harbor Freight. I cut off the shaft of a cheap small screw driver to create a flat welding tip for the iron. I also used black as well as "clear" tie wraps for sources of filler material.
The repairs look ugly but it is much less work than using epoxy (my previous repair). I have to swap out the bastardized harness on this dash with one from my left over dash. I will let you know how long the repair holds up. Flexing the repair by hand the repair seems strong. Remember this is a compression stressed attachment on the car.
The screw holder was somewhat tedious as you must slowly build up the material. I will drill a pilot hole for the screw so as not to crack the repair.
Good Luck.
1998 S70-T5 201,000 miles
Good Luck.
Ahmed
Nov 7, 2014 05:14 PM
rspi
Aug 13, 2013 04:27 PM
