Dipstick Leaking Oil?
Old Feb 19, 2009 | 02:26 PM
sRed70's Avatar
Default Dipstick Leaking Oil?
My dipstick keeps popping out and spraying oil everywhere in my engine. It seems like there is some kind of pressure pushing it out causing it to spray every where?
Any one else have this problem?
Old Feb 19, 2009 | 07:16 PM
Either the vent box or something in the vent system is clogged.
Old Mar 7, 2009 | 10:31 PM
sRed70's Avatar
Ok had the pcv system totally replaced and some vacuum lines done. No more oil coming out but smoke still comes out of the dip stick when I take it out.
Is this normal?
Old Mar 7, 2009 | 10:33 PM
sRed70's Avatar
Also I have to clean my engine bay it is filthy. Any tips?
Old Mar 8, 2009 | 10:14 AM
You might have a real tiny bit coming out.
Also remember it might need to finish burning some off from before when it was clogged.
Don't spray to much water on the motor itself.
Try to wipe most of it off.
Old Mar 8, 2009 | 03:23 PM
sRed70's Avatar
ok thanks. My car is still spraying something all over the engine cleaned it took it for a ride and its covered again. Im not sure if its oil or something else. Its getting me mad.
Old Mar 8, 2009 | 04:41 PM
HMMM I would try to track it down soon.
Old Mar 9, 2009 | 05:19 PM
sRed70's Avatar
Oil is still coming out of the dipstick. Thats what the spray is. I was told my dipstick isnt the right one and it makes it pop out. Then when driving at higher rpms it sprays every where.
Old Mar 9, 2009 | 07:38 PM
If it is poping out then something in the vent system is clogged causing to to pop out.
Old Mar 9, 2009 | 07:51 PM
sRed70's Avatar
No not popping out just not sealing up right when you push it down.
Old Mar 9, 2009 | 08:01 PM
Johnny Mullet's Avatar
It still should not blow oil like that. I agree with tech about the vent system clogged (flame trap?) causing the blowby.
Old Mar 9, 2009 | 08:05 PM
Yes then maybe it is the wrong one.
Old Mar 9, 2009 | 08:10 PM
sRed70's Avatar
I just had the vent box replaced (and all the lines) so it cant be clogged.
Old Mar 9, 2009 | 08:12 PM
Get the right dipstick for it. You may need to buy a new tube as well.
Old Mar 9, 2009 | 08:13 PM
sRed70's Avatar
Ok just order a new from fcp. Hopefully this solves my 3 month long journey to stop oil from leaking.
Old Mar 14, 2009 | 02:27 PM
sRed70's Avatar
I bought an dip stick from fcp. It seems that the one they sent doesnt fit but a one from an 850 does fit. Why would this be?
Old Mar 14, 2009 | 09:29 PM
  #17
Most likely because they should have sold you a tube as well.
Old Mar 15, 2009 | 04:53 PM
  #18
sRed70's Avatar
How hard is it to install the tube?
Old Mar 15, 2009 | 06:38 PM
  #19
Pretty easy one screw then swap the tube.
Volvoguy505
Jun 6, 2018 03:10 PM
supernicguy
Jan 22, 2010 06:21 PM
mercb
Dec 11, 2009 01:49 PM
NCS60
Apr 5, 2007 12:53 AM
MattB850in
Mar 29, 2007 03:55 AM
