door lock inoperative
Old Sep 6, 2006 | 07:49 PM
maddox's Avatar
Default door lock inoperative
I have a 98 S70 4 door with power locks. The rear drivers side door lock gave up and would only close and not open. I replaced it with a used and it worked for a few days and now is back where it started (only close and will not open). Now did I just get unlucky when it stopped working or is there something else that controls this door lock? If nothing else controls it then I was unlucky. How much are these new and can you get a better price online somewhere? Is there anything else I can try to find out what the culprit is?
Thanks in advance.
Guy
Old Sep 6, 2006 | 09:07 PM
Default RE: door lock inoperative
I think you just got Unlucky.
Old Oct 4, 2006 | 09:35 PM
elbert's Avatar
The locks have a poor design. There is a hook mechanism that is prone to breaking. Go to this link to see what I mean -www.volvospeed.com/Repair/v70latch1.php. I was successful on repairing it. It was certainly difficult and trick to repair. No easy task.
Old Oct 17, 2006 | 02:14 PM
CosimaW's Avatar
I have the same problem. Was quoted $700. to fix---and decided to live with the problem.
Cosima
Old Oct 17, 2006 | 03:26 PM
elbert's Avatar
No way! Not $700.00.
I'm not sure what model you have or which side of the door is malfunctioning but there is a new lock unit on ebay right now for bid for about $100.00. I had to rebuild the unit itself which was the hardest to do. If you get a new unit, it is a much easier project. If your are a littlbe bit handy with tools, you can install it yourself. It would take a novice maybe 2 hours the very most. Just imagine what you can do with $600.00.
Old Dec 9, 2006 | 10:07 PM
stevejanosik's Avatar
Thank you elbert for posting that link. I replaced mine with an used whole assembly. I won't have the confidence to do it myself without that instruction.
Old Dec 10, 2006 | 09:59 PM
elbert's Avatar
Stevejanosik, you're welcome!
Old Dec 17, 2006 | 02:37 PM
OvloV 13's Avatar
subscribing for future reference. Thank you.
Dave_Park
Mar 10, 2023 03:04 PM
allenzachary
Mar 14, 2012 08:55 PM
Alaska 850
Jan 7, 2011 04:21 PM
pfh1212
Dec 7, 2010 10:23 AM
maddox
Aug 5, 2006 01:25 PM
