Early Model S70 Performance High Miles
Old Jun 16, 2010 | 02:22 PM
19_Volvo_S70_GLT_98's Avatar
Default Early Model S70 Performance High Miles
I have a 1998 Volvo S70 GLT with 180k miles on it no horrible engine probs or anything one code for a coolant temp sensor and my oil trap is clogged both of which im currently fixing, i ran into another problem this week with my exhaust. it broke off completely where there is a flange after the Cat where it gets smaller and i was wondering if i can replace the original muffler and that section with a Thrush glass pack straight through pipe. I want to add a little HP, i was also looking into high flow cat's too. Would the straight through pipe cause not enough back pressure or too much to where this would not be the right application and just go with a aftermarket magnaflow or somthing of the sort.
I would like to get some other things done such as the Short Ram air intake, HD turbo control valve.
Would these parts put too much on my old motor?
Thanks again for looking!
And comments and tips are very greatly appreciated.
Old Jun 16, 2010 | 05:50 PM
You can get most of your answers at www.IPDusa.com or http://www.fcpgroton.com/.
To see what condition your motor is in before mods, you may want to have a compression test done before going crazy.
V70Fan1940
Nov 11, 2016 12:59 PM
daver80
Oct 27, 2014 10:52 AM
gccarter
1998-2000 model year V70
Sep 18, 2014 11:47 PM
boostnm3
Dec 14, 2010 09:39 AM
Gcm
Oct 1, 2010 10:51 PM
