Engine managment model
Old Sep 19, 2008 | 03:58 AM
karpas's Avatar
Default Engine managment model
I have a '99Volvo S70 GLT(Belgian built), with a B5254S (2.435liter) 20v gas. engine anda/t trans and 140000 Km (87000miles), The EM is Motronic4.4 (according to the manual). the connector (in the arm rest) has OBDII on the cover
1.How can I find out if this is the eng. management model?
2. How many RPM should it show at idle hot/cold (it is now about 900)?
3. Can anyone recommend a code reader that will show what the code is and erase (without batt. discon.)
The check engine came on about 3 weeks ago and I borrowed a code reader and as far as I could tell it showed a timing error, the car sounds/runs ok I disconnected the batt. but after about 3 days the Check eng light came on again, yesterday it went off by itself (maybe the computer is so smart it fixed itself !!!).
Israel
Old Sep 19, 2008 | 07:30 PM
Default RE: Engine managment model
The 99 car should be a ME7 system not the 4.4 system.
Old Sep 20, 2008 | 01:49 AM
karpas's Avatar
I looked for a label on the chasis or engine but couldn't find anything that shows the EM system, like i wrote the manual says Motronic 4.4, how can i find out if this is the system before i buy a code reader that won't work
appreciate ur help
Israel
Old Sep 20, 2008 | 01:52 AM
karpas's Avatar
appreciate ur help
Israel
Old Sep 20, 2008 | 08:09 AM
Does your car have a throttle cable?
Does it have a full electronic setup?
Old Sep 24, 2008 | 12:34 PM
karpas's Avatar
I can't find anything that looks like a cable throttle, there is a light on the dash marked ETS, so I guess it has an elect. throttle
Israel
Old Sep 24, 2008 | 06:54 PM
If you have the ETS light then you should have the ME 7.0 system.
Old Sep 25, 2008 | 12:08 PM
karpas's Avatar
Thank u, Israel
tina2222
Nov 15, 2014 10:06 PM
desolator
Jan 8, 2011 04:08 AM
cw4dug
Sep 11, 2010 03:26 PM
obio
Jul 2, 2006 02:18 PM
mhallbd
Oct 25, 2003 05:45 AM
