Exhaust Noise after upper engine mount replacement
Old Jan 30, 2010 | 05:22 PM
jg1's Avatar
jg1
Default Exhaust Noise after upper engine mount replacement
This is a strange problem. Replaced the upper engine mount (the one that attaches to a bracket mounted to the engine and then a torsion arm that mounts at the firewall). This mount was difficult to install and required quite a bit of hammering to get in place. I probably should have removed the bracket from the engine and made a jig as suggested in other postings, but regrettably I opted for brute force.
In any event after replacing the mount I notice increased exhaust noise. I looked under the car and didn't see anything obvious. I didn't actually check that all of the header bolts, and exhaust connections are tight. What should I check and what could account for the increased exhaust noise?
Old Jan 31, 2010 | 03:24 PM
Anytime you replace a mount there is a big chance that you can expose another weak link. I would check the exhaust connections and your passenger side motor mount.
Old Apr 23, 2010 | 05:59 PM
jg1's Avatar
jg1
Good call on the right engine mount, thx
CaliS80T6
Sep 12, 2009 09:20 AM
leebae
Sep 18, 2007 08:07 AM
leebae
Jun 17, 2007 10:28 PM
adub96
Nov 19, 2006 07:18 PM
