Few Problems
Old Jun 30, 2009 | 09:32 PM
jweston5's Avatar
Default Few Problems
Hi,
Just curious if I could get some advice on some nagging problems that are present on my 2000 S70. First on my trip computer, the back light isnt working on the right side when the night lights are on? Suggestions?
And secondly my driver rear window seems to get stuck at times but goes up eventually. When its stuck there is no moving it. Any suggestions?
Thanks Again!
Old Jun 30, 2009 | 11:18 PM
s70_t5_1999's Avatar
mine does that too. it could be a bad window switch. does it sound like anything's happening when you press the button?
Old Jul 1, 2009 | 07:18 AM
On the trip computer, the bulb needs to be replaced.
As for the rear driver side window, does it go up when you try the rear door switch? The likely culprit is the drivers door control cluster, they do go bad. If works fine with the switch on the door, then it is likely the switch on the drivers door. Most people end up replacing the entire driver door cluster, not sure if it can be taken apart and repaired.
Old Jul 3, 2009 | 03:16 PM
BlazeS70's Avatar
My front passenger side window takes a horribly long time to go up...is that the control cluster too or is the motor going bad?
fadam
Oct 16, 2017 06:27 AM
renejuan
Oct 21, 2008 09:34 PM
redknight
Apr 12, 2008 04:00 PM
Colinruss
Dec 12, 2007 05:10 PM
Demlotcrew
Nov 17, 2005 03:15 AM
