front end vibration
Old Jun 1, 2010 | 08:29 AM
mnvolvo's Avatar
Default front end vibration
I just started noticing a vibration type of noise from the front end of my 99 S70 AWD. The vibration pitch increases with speed and is especially noticeable when I turn the wheel to the right, and it almost disappears when I turn the wheel to the left. The noise is a constant hum, not like a rotational noise where there's a pause as the tire rotates around again. I hope this is descriptive enough...
Last time I had the car serviced, they noted that I had a loose right tie rod. Could this be vibrating and causing the noise? I also just had the tires replaced a month ago, but hadn't noticed this noise until this last weekend... Any suggestions would be very helpful before the mechanic starts giving me a laundry list of things to fix. Thanks!
Old Jun 1, 2010 | 11:08 AM
SVTfocusO3's Avatar
Tie rod inner's and outer's are a good place to start.
Old Jun 1, 2010 | 01:00 PM
Somthngfrce's Avatar
also check your axles
Old Jun 2, 2010 | 11:24 PM
akem21's Avatar
Could be a wheel bearing. If it's louder when turning to the right, it's most likely the left wheel bearing because that's where the weight of the car is shifting to.
Old Jun 6, 2010 | 08:07 AM
s40volvo's Avatar
Same situation here. I have a loud hum while driving but gets louder when i turn right. I just had 4 new tires put in with both front and rear alignment. Last time this happened to me in my other car, it was the bearing.
I had my tires changed at Town Fair Tires. The guy inspected the car and told me he didn't see any movement in the wheels. So I was thinking if it was a tire rod it would have been obvious to them. Bearing on the other side is not obvious all the times unless you're driving.
Any suggestions?
Old Jun 7, 2010 | 12:24 AM
2004VolvoS60_Bilal's Avatar
Check Your inner/outer c/v joints.
Old Jun 7, 2010 | 09:47 PM
I would start with checking the tires. Make sure they are balanced.
Then I would check the wheel bearings. A small pit in a bearing can cause the noise, it will only get worse. Bearings are a pretty easy fix. That was the problem with a Honda Accord I had.
RPMCanes
Sep 10, 2016 09:58 AM
casualfc
Oct 6, 2008 09:34 AM
ocean238
Apr 17, 2008 06:20 PM
DaveNY
Aug 2, 2005 10:03 PM
JimKW
Jun 14, 2005 06:38 PM
