hard knock on right side
Old Aug 28, 2010 | 09:15 PM
kennedy759's Avatar
Default hard knock on right side
2000 S70 turbo, when I hit a pot hole on the right side, I feel and hear a hard knock on the right front, what kind of problem do I have?
Old Aug 28, 2010 | 09:22 PM
akem21's Avatar
There could be a couple things causing that. My guess would be a bad sway bar link, worn sway bar bushings, or the upper strut mount.
Old Aug 29, 2010 | 06:52 AM
bw77's Avatar
Could also be the engine mount under the crank pulley is worn out.
Old Aug 29, 2010 | 12:10 PM
EEaudio08's Avatar
I was having the same problem, and I eventually ended up replacing the entire suspension/steering system. The first run, I replaced the struts, spring seats, shock mounts, and swaybar endlinks. This solved the problem for a while, but then it came back. The second run, I replaced the inner/outer tie rods, control arms, and heavy duty swaybar endlinks. Since the second run, I haven't had the "knock" come back. I also replaced the right spring seat a total of three times, thinking it was the weak link.
In a nutshell, I would say that the problem is either the control arms or the swaybar endlinks. I would suggest the iPd heavy duty swaybar endlinks - they're relatively cheap and ridiculously easy to replace. If that doesn't fix it, I would try replacing the control arms. Not a simple job, but not too difficult. The bushings on my blown control arms were completely destroyed - basically non-existent.
Best of luck with the repairs!
Old Sep 18, 2010 | 07:32 PM
kennedy759's Avatar
replaced the sway bar links, looks like that was the problem, will know for sure when I drive it to work.
Old Jun 29, 2011 | 12:21 PM
WYS70's Avatar
So our son's S70 is making a clunking sound on the right side. Is there a swaybar end link on both sides or just the right side? Never mind got a chance to look at the car.
Old Jun 30, 2011 | 09:12 AM
WYS70's Avatar
Went to Napa yesterday and bought 2 new ends. Clunk is gone and all is well again.
rdklxprs
Jul 21, 2015 09:46 AM
andrewwhite149
Apr 22, 2012 01:33 PM
ruggles
Mar 3, 2010 04:19 PM
jerryman
May 23, 2006 01:19 AM
lizard
Sep 1, 2005 08:48 PM
