HELP :S70 AWD propeller shaft
Old Aug 6, 2006 | 11:51 AM
alireza1344's Avatar
Default HELP :S70 AWD propeller shaft
I have a 1999 S70 AWD with 200k (Km). There is grinding noise that coming from front of the car. Dealer ( Volvo villa, Toronto) told me that I need a new propeller shaft. They also told me that this shaft can not be repaired. price is $1300 only for part + 2 hours of repair time. I wonder if anybody had the same issue and can give me some hints
Old Aug 6, 2006 | 12:06 PM
S70driver's Avatar
Default RE: HELP :S70 AWD propeller shaft
I have the same car and I have not experienced this.
S70driver's Avatar
What is this part your talking about? What exactly does it do?
Part of the 13g turbo in our cars? Or something else.
Old Aug 6, 2006 | 12:09 PM
S70driver's Avatar
A propeller shaft connects a propeller to an engine. It is also the British English term for the driveshaft which connects an automobile gearbox to a rear differential. It is commonly referred to as a "prop-shaft".
Where the engine and axles are separated from each other, as on four-wheel-drive and rear-wheel-drive vehicles, it is the propeller shaft that serves to transmit the drive force generated by the engine to the axles. For its usage, the optimal shaft is a short, bar-like product. The longer the bar, the more liable it is to sag, and sagging is further promoted when rotation is applied. Sagging causes vibration and results in an increase in noise, to such an extent that the shaft is likely to break when the critical speed is exceeded. The propeller shaft is naturally designed not to break when used within the service limits expected of use. In addition, it is designed to suppress vibrations arising from a wide range of causes.
Quoted from Wikipedia.
Old Aug 6, 2006 | 12:11 PM
S70driver's Avatar
Does this grinding noise happen all the time? When your turning right or left? or at full wheel lock?
I have a groaning noise coming from the front of my car, but it has something to do with the steering and it happens no matter if I am sitting still parked, turning, etc...
Bernholtz
Aug 2, 2009 12:39 PM
CassMori
Jun 5, 2009 09:56 PM
basha53
Mar 24, 2008 05:29 PM
Volvo V70R
Feb 1, 2008 06:24 PM
mjnajjar
Feb 25, 2007 11:44 PM
