hi new guy here, needs some info
Old Apr 11, 2011 | 09:16 PM
bonecrusher's Avatar
Default hi new guy here, needs some info
hi
just purchased a
1998 s70 t-5
with 220k miles in really clean condition
automatic etc etc
has a few codes
po102,po300,po302,po304,po410,po455,po505
and has a decent oil leak from somewhere on the backside of the engine, cant visually see it from the top
what should i start with first? plugs wires cap and rotor?
thanks
Old Apr 11, 2011 | 09:50 PM
Congrats on the ride. Looks real good.
Just do it all at the same time. Tune up kit and probably the turbo return like seal.
Old Apr 12, 2011 | 02:15 PM
think that will solve most of my problems?
where is the turbo located at? back side of engine?
Old Apr 12, 2011 | 05:22 PM
yep... in front of the steering wheel side.
Old Apr 12, 2011 | 06:20 PM
think that could be my oil leak? is there any real common oil leaks on these? mine is leaking i believe backside of engine but i couldn't see where but its a pretty decent leak and only when it warms up
Old Apr 12, 2011 | 09:31 PM
I have a thread about oil leaks on our S70. I also did a write up on stopping the cam seal leaks (replacement). There was a little plate on the back of our motor that was leaking, I had to order and replace the gasket. I have one or 2 more gaskets if you need them.
The turbo return line connection is the most common leak back there.
Old Apr 12, 2011 | 09:41 PM
If you look at the mount and shaft, just above the shaft and right of the mount, you will see the turbo. Just right of the turbo you can see the turbo return oil line that is bone dry here, it has the line going through the bracket with a bolt or two with a seal behind the bracket.
Old Apr 13, 2011 | 03:05 PM
okay I am having a buddy who is a ase mechanic and knows his stuff check it out and i will find out for sure what is leaking and let you know on that gasket
thanks!
Old Apr 14, 2011 | 05:48 PM
would any of the leaks you mentioned only leak when its warmed up? It won't leak when started or sits for a while, just when its warmed up etc
Old Apr 14, 2011 | 09:52 PM
Probably leaking when pressure or boost is applied.
Old Apr 15, 2011 | 02:32 PM
bring anything up in your mind? or could it be anything?
Old Apr 18, 2011 | 01:04 PM
ttttt
frtdrmrose7
Dec 18, 2011 06:50 PM
Goalcrease
May 2, 2011 04:49 PM
stangcb
May 5, 2010 04:30 PM
pultry
Jul 16, 2009 07:04 AM
jjm72
Feb 8, 2009 06:20 AM
